Profile View - first and last label is the station band is not displayed
Message 1 of 18
hello everyone
i am working with profile view, everything is ok except that the first and last label is not displayed in the band corresponding to station, although the check box corresponding to the "label start" and " label end"is checked. here are two images showing the profile view and the profile view setting
Replies (17)
Message 2 of 18
civilman1957
Click on your profile view and right-click, go to profile properties. Go to the "bands" tab. In the large box at the bottom, your band type should be shown. The ninth and tenth columns should say "Label start station" and Label end station" respectively. Are those checked? If not, they won't be labeled.
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 3 of 18
did you mean those setting? Images one or two, if no where can i find them.
Message 4 of 18
civilman1957
No...sorry...I should have said click on the profile view, right-click and select profile view properties. When the dialogue box opens up, go over the the "bands" tab...it should look like this -
Notice the two arrowed boxes....Label Start Station and Label End Station...ensure those are checked in your profile view...
Message 5 of 18
the problem is that these two boxes were checked before everything, still doesn't  work
Message 6 of 18
Dexterel
Upload the DWG, need to check band label style.
This should be 100% fixable.
Message 7 of 18
MikeEvansUK
I'm not sure this has ever worked for me unless the start / end is located on a normal chainage (0.000, 10.000) or at the absolute start of the profile view.
My advice is to either add a station equation, turn on Horizontal data or just add a label manually.
M
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 8 of 18
I added the station equation but nothing happened
Message 9 of 18
razkaman
just try to import band set in profile property in band tab. or redo all the process, sometime something like this happen, usually if there are to much editing
Message 10 of 18
Dexterel
Ahachem add a DWG and we will solve it in 20-30 min.
Maybe you don't have a profile on 0+000 station or end station, a layer is off, many possibilities, style is not correct and so on.
Message 11 of 18
cwr-pae
Someone may have turned off some of the band labels. Try a right click on the band and selecting "Reset all Group Labels".
Message 12 of 18
andrewpuller3811
This is a problem that has been going around for a while.
Bring up the profile view properties, and select the Stations tab.
Set the Station range to User specfied range.
Select the entire value in the Start: text box and type in 0 (assuming this is your alignment start station value)
Select the entire value in the Ed: text box and type in the value of the alignment end station. Only enter the number, not the units.
If that does not work, enter 0.0001 as your start station and subtract 0.0001 from  your end station and enter it in the end station box.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Message 13 of 18
go to profile view style -> grid, change the grid padding to left: 0.01 to start grid slightly before station 0+00
Message 14 of 18
saifumk8
@andrewpuller3811
I tried to updated start and end station as you mentioned, however once it showing start and end elevation same time start and end chainages are missing.
Message 15 of 18
paliwal222
Thanks, Andrew it,s work.
Message 16 of 18
Nick_Antonov
I know this is Old but I was also looking for solution and going trough the answers it guided me to the correct solution that is not relay mentioned here.
But one post guided me where to look for solution : Display Tab
I found that if I switch off : "Label Horizontal geometry Points" on the Profile Data bands, Then it shows the Start data..
Message 17 of 18
n_h_pham
Tried all of the above. This has bothered me for years...  Decided to turn down the weeding to 0 as it was automatically set to 100 during creation as per @civilman1957 image and low and behold the start and end labels now appear. Hope that helps some people!
Message 18 of 18
denniskomen2
Years later this worked for me along with Label Vertical geometry Points but I still haven't found a solution for the last label.
Edit: When publishing view frames and sheets somehow the last label shows up which is good enough for me
