Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
The profile isn't labeling correctly from sheet 2 to 3. Any help appreciated.
Solved by MMcCall402. Go to Solution.
That doesn't work profile length matches the plan.
You'll notice that if you click the curve before, they are somehow "attached". It'll just be another explosion when it's all said and done.
If the anchor point of either end of the dimension line is outside the limits of the viewport then the line won't be drawn.
Try editing your curve label style and change the anchor point(s) for the dimension line. There is a start and end point that is limited to within the viewport.
