Profile not labeling across sheets
LucasHicks
LucasHicks
The profile isn't labeling correctly from sheet 2 to 3.  Any help appreciated.
OpenRoads Designer, Civil 3D
wfberry
If you break your profile at Sta 11+20, everything looks hunky-dorey.
Bill
LucasHicks
That doesn't work profile length matches the plan.
You'll notice that if you click the curve before, they are somehow "attached".  It'll just be another explosion when it's all said and done.
MMcCall402
If the anchor point of either end of the dimension line is outside the limits of the viewport then the line won't be drawn.
Try editing your curve label style and change the anchor point(s) for the dimension line.  There is a start and end point that is limited to within the viewport.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
LucasHicks
Thanks, that did the trick.
