When I select a PVI node on my profile and try to move it to a new location the node moves twice as far from the point of origin as my cursor. This means that my node is not staying with my cursor and makes snapping impossible.
I have had similar problem with labels doing this when I try to perform two consecutive actions on a selected label. However I could get around this by unselecting and selecting again. This does not work on my profile.
Does anyone know what is causing this or is?
Solved by codee. Go to Solution.
There is a button in the Edit Geometry panel for "Move PVI". When you select that is solves the issue.
At the Command: prompt, type Plan, then W for World, enter. Try it again.
Thank you but it did not fix the problem.
