When creating profiles in previous versions of C3D you could create the profile, then if you wanted to set specific ranges for sheet set up you would just copy and set that range and be done. With the 2019 release it seems that when you do this it copies the surfaces and will not copy the curve data or labels over into the new profiles. Is this a known issues or just a setting that needs to be set with 2019?
