Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Production cross section is only allowing one section per sheet.
9 REPLIES 9
Message 1 of 10
Akb33F54
2170 Views, 9 Replies
I'm trying to work with the odot 2018 state kit civil 3d template. We've had to tweak a few things here and there to work with plan production tools. They had a title block for cross sections, but we made it a .dwt with a layout with a section viewport so we could use civil3ds output tools. I've finally figured out that changing the group plot style array to starting in the lower right and aligning left gets my sections to fit on my sheet rather than hanging over the edge. its slightly off center though.  It had appeared before changing the array that there was some sort of x offset in place pushing my sections off the right edge of the sheet. after changing the array rules 70,70 sections seemed to fit perfect on the sheet, but the section boundary overhung the edges and had the elevations right at the edge. Changing the offsets to 65,65 makes the entire section, and its boundary fit completely on the sheet, but my sheets are still only coming in with one section per sheet. I'd be happy to share any other helpful parameters that may be helpful.
Labels (1)
9 REPLIES 9
Message 2 of 10
igi_pop
in reply to: Akb33F54
Hello!
Are you maybe counting your sections horizontaly then verticaly? Cause you have plenty of room verticaly 🙂
If so, try changing that order (vert then hor) and re-do them.
They are a bit of a pain untill you finally nail them.
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Message 3 of 10
Akb33F54
in reply to: igi_pop
I attached a snip from the plot style array. I have it set to "by column". I did go ahead and try changing it to "by rows" but it stacked all sections on top of each other. I changed it back to "by column" and its still only putting one per sheet. Am I missing something?
Message 4 of 10
igi_pop
Ok, i've just created some sections to remind myself how to work it exactly. I'm gonna just tax it:
- you need to figure out the scale for the output will be, for instance 1:100 (i'm metric, sorry)
- that will give you the output width/height of each individual section
- in the template you created, your viewport needs to be big enough to fit 2 of them, either way, and set up for sections.
- when creating section frame, your MODEL SPACE must be at the desired scale (same as template layout)
- from what i see, no matter what the start point and direction of counting is selected, it all rearanges to the frames
- bare in mind the distance between adjacent section views. after i reduced the distance to 0mm, it fit some pages with 4 sections (screen attached)
Maybe some of this helps, or rings a bell.
Ask away 🙂
Message 5 of 10
sboon
I did an Autodesk University class on this topic a while back.  Search the AU website for CI1527.
Steve
Steve
Expert Elite Alumnus
Message 6 of 10
Akb33F54
So I was able to get multiple on a sheet by making my section view offsets smaller, but I still can't get it centered. I feel like there's some sort of forced offset somewhere that I'm missing. I've spent a lot of hours trying to get this worked out this week. attached is what a sheet looks like with a 60 left and 60 right offset. Also is a summary of the plot style and section view style. Thanks for trouble shooting with me.
I did confirm that my model space is 1:5 as well as my viewport scale.
Message 7 of 10
sboon
Turn on the display of the Major horizontal and vertical grid lines in the Group Plot Style.  The rules are:
  • Each section view is inserted at the intersection of two major grid lines.
  • There must be at least one major grid line separating adjacent views.
I suspect that you have the Plot Area grid details set incorrectly.  Once you can see the grids try editing the major grid spacing until you get it working the way you want it.
Steve
Steve
Message 8 of 10
igi_pop
@sboon is correct, changing the vertical grid will move your sections left<->right, horizontal up<->down. The problem here can only be if your sections are not uniform in size, i guess. I'm gonna check out the AU post @sboon suggested, as I'm always into learning stuff 🙂
Cheers, and good luck!
Cheers,
Iggy
Message 9 of 10
Akb33F54
Now I'm questioning if there isn't some drawing setting that can force (annotation?) things to offset. I just tried modifying a pipe label style so that the text anchor point is the bottom outer diameter, and the text attachment is top center, with no x or y offsets and the text is coming in about .38x the scale away from the pipe.
Message 10 of 10
Akb33F54
I figured out the pipe label offset issue. The text border that was not on, was set to circular.
Rail Community
