Production cross section is only allowing one section per sheet.
I'm trying to work with the odot 2018 state kit civil 3d template. We've had to tweak a few things here and there to work with plan production tools. They had a title block for cross sections, but we made it a .dwt with a layout with a section viewport so we could use civil3ds output tools. I've finally figured out that changing the group plot style array to starting in the lower right and aligning left gets my sections to fit on my sheet rather than hanging over the edge. its slightly off center though. It had appeared before changing the array that there was some sort of x offset in place pushing my sections off the right edge of the sheet. after changing the array rules 70,70 sections seemed to fit perfect on the sheet, but the section boundary overhung the edges and had the elevations right at the edge. Changing the offsets to 65,65 makes the entire section, and its boundary fit completely on the sheet, but my sheets are still only coming in with one section per sheet. I'd be happy to share any other helpful parameters that may be helpful.
