I've been using TCOUNT for a while now but this is the first time I've encountered a problem. The command seems to be numbering along the X axis (as I want) from highest X value to lowest (so it reads right to left) which is the opposite of what it is supposed to do and what it has done in the past for me - and even in one of the viewports of the project I'm working in. Is there a way to reverse this or reset it? I should mention that I'm working through multiple viewports, and in each one selecting the UCS based on an object to set the X axis for my TCOUNT command. Thanks!
Your numbers are going in the wrong direction because you have not chosen the 'X' option for sort selected objects. Instead, you have chosen the Select-order option which will create numbers in the order that your crossing window has selected the objects. Either properly select the X direction option or draw your crossing window in the opposite direction.
If you are working through a viewport then your UCS is rotated so positive x is to the left while x=0 is to the right. Does your activated VP have a UCS symbol? does that UCS symbol have a small square at the intersection of the x and y axes? If there's no square, then your UCS is not set to World and your Positive X-direction may be pointing the wrong way and since it's responsible for the numerical sequence your numbers are going the the wrong way too.
You have multiple options:
I apologize for the poor example but please see the attachment. I had to use screenshots to show what I'm doing - screen cast is not working, and I am at a company computer so it is not possible to change settings.
1. I cannot use world ucs in model space because objects are at strange angles and X axis option will not work.
2. Direct select will work, but I'm trying to avoid it as I have hundreds of objects and it will be very time consuming.
3. I have rows of varying lengths, and I'm numbering across each row starting at the left, so using the last number (your example 10) and counting backwards would also be extremely time consuming and probably multiple errors as I'd have to count each row manually.
My placed UCS is accurate in that to the left are smaller values and to the right are larger. There must be something wrong with the program.
No, there isn't anything wrong with the program. Your x-values are negative so the numbering sequence in the TCOUNT command is opposite and goes from right to left.
It happens whether or not the numbers are negative. Moving the origin does not affect the result.
