Hi @khaledCULN8 ,
Thank you for providing all the details. I've looked into your file and tried different settings (e.g. changing frequency of the corridor) - no luck.
It looks because of very complex geometry and quite developed assemblies(targets, conditions) which are changing their layout accordingly to the conditioning targets, Civil 3D encounters problem to export alignment with the associated profile correctly. It is hard to find one direct location that causes the problem as the model is in quite advance stage.
In this situation, I recommend you to Create Alignment from the Corridor and create a profile from Surface (existing ground). It should reflect the elevation of the intersection point between the existing surface and vertical wall.
Another solution is to create a feature line from the corridor and display Quick Profile with a 3D entity profile displayed. After that, you can export it to LandXML, delete the origin feature line, and import it back as an alignment and profile. It's a simple trick, but it works perfectly. Please see the screencast that explains this solution step by step: Export feature line to alignment and profile
I hope that the above will help you to move forward with your project works. If you need any additional assistance please respond and I will be happy to help.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Technical Support Specialist
Civil Engineering Solutions
