Hi, im crating a corridor from an excavation, but the excavation have 2m in the start and 4m in the end, i create the assembly with "LinkOffsetAndSlope" and "BasicSideSlopeCutDitch", for the offsetts i select two polys (one for each side), the right one has no problem but the left one seems not to make the offset on the slope, the width of the excavation recognize the offset, but the slope to te Natural Ground doesnt. I don´t know what i'm doing wrong. Thanks.
Solved by ecfernandez. Go to Solution.
Hi @antgarcia114, I hope you are doing well. Select the left BasicSideSlopeCutDitch subassembly, go to the ribbon, and select the "move" button. Then, select the end of the LinkWidthAndSlope subassembly as the new location to move the slope. We know it is already there, so you are basically, confirming your geometry. Assign targets for the BasicSideSlopeCutDitch once more and rebuild.
Please let me know if that works for you. Best regards!
Hi, thanks, that work, the other way i found was simple delete the BasicSideSlopeCutDitch, beacause i mirror the right to create the left, so i deleted and placed from scratch and worked, but your solution also worked.
That’s good to know. Thanks for confirming it worked. Best regards @antgarcia114
