I'm using civil 3D version 2018. I have a problem with a curve in a corridor. It's creating a bowtie I cannot fix, without creating other problems in the corridor. After using the clear bowties option, the bowties desapiers, but I have big changes in the width of some lanes.
The pictures showned here are before and after I clear the bowtie.
Is there a way to fix this? I have already tried to split the corridor in more than two regions. I need to have the exact width and cannot change the assemblies because of the materials count.
Thank you for any help.
Solved by M_c3d. Go to Solution.
Try using polylines to target your corridor and increase the frequency of the corridor. Also try increasing the radius on the bend using the alignment drag options, this usually removes bowties
This is never going to be an easy thing to model, the tight curve with wide non carriageway area is always going to be problematic. The design has to change or you will need to change your assembly / modeling method.
Just working it through in my head, this is what I would try.
like I said that’s off the top of my head, without testing. But that’s the route I’d try
I have used targets from the begining, but after fixing the bowtie the corrider looses the target somehow, even thought the target is still marked.
I tried modifying the frequency, with no sucess.
Regarding the radius I'm not able to change it, because this is an already existing road, I'm only changing it's width and the outside (sidewalk, parking..)
Thank you for your sugestions!
remove the target and re add it, this usually fixes that. Sometimes after a significant change it can not recognise it
I'd use an offset assembly along the smaller radius, then build the offset assembly back to the roadway.
