problem launching Dynamo in Civil 3D 2025
wanlop_luanwuttipong
Steps to reproduce
  1. download Dynamo Sandbox 3.1.0 and run
  2. install Civil 3D 2025
  3. not able to get Dynamo (3.0) inside Civil 3D 2025 to run
the workaround I did, change the Core folder under C3D\Dynamo\ to be the one from 3.1, and then I can get Dynamo running inside Civil 3D 2025. But I would like to run the original from Civil 3D.
Please help
PS: I already tried this but it did not help
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Dynamo-extension-i...
VincentSheehan
Have you tried to reinstall Dynamo after you installed Civil 3D?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
@VincentSheehan Dynamo Sandbox is just a zip file, with no installation. Unzip and run the sandbox.exe. (and Dynamo in the Sandbox is a newer version than the one with Civil 3D.)
