Civil 3D Forum
Problem in some dialog box Map 3D tools
8 REPLIES 8
Message 1 of 9
780 Views, 8 Replies
Good Morning.
I am having the following problem in C3D 2015 and Map 2015:
Some tools from Map 3D does not open the corresponding dialog box.
The options appear on the command line as below pictures:
Has anyone ever experienced this problem? Anyone know what this is?
It is a variable filedia system.
The software has been updated correctly.
Thank you
Adriana
8 REPLIES 8
Message 2 of 9
antoniovinci
You'd better add the Support path to the Files section under _OPTIONS command: wait for the "graphic" advice of other gurus, 'cause I have no 2015...
Message 3 of 9
Pointdump
"Graphic" advice. I like that! I'm not nearly the guru that Antonio is, but I think you probably just need to set FILEDIA to 1. You can test this by entering the tilde in the command line:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 4 of 9
antoniovinci
in reply to: Pointdump
No way, Dave: it's a matter of missing "Support File Search Path" in the _OPTIONS interface, trust me.
Message 5 of 9
Pointdump
in reply to: antoniovinci
OK, Antonio. Which one is missing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 9
Pointdump
OK, so when I click "Attach/Detach Object Data", I get "No Table is Defined". When I click "Define Object Data" I get this dialogue box:
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 9
alexlibrelon
Verify variable CMDDIA is set to 1
Alex Librelon
Projetista Master - Youtube | Blog | Linkedin
- Marque a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Clique em "Curtir" caso a resposta tenha ajudado;
Message 8 of 9
david.zavislan
The missing path that Antonia is referring to is:  "C:\program files\autodesk\autocad 2015\map\support\en-us".
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 9 of 9
in reply to: david.zavislan
AutoCAD2014
Unknown command "MAPTRIM".
I cannot find the path wich solved your problems  C:\Program Files\Autodesk\AutoCAD 2014\Map\Support\en-US, if it is the same as in 2015 ( C:\Program Files\Autodesk\AutoCAD 2015\Map\Support\en-US) I don't seem to have a  "map" folder at all in the "autodesk" folder.
CMDDIA and FILEDIA bot set to 1.
Anyone been trough this?
Best regards
Rail Community
