Problem creating profile from file
 I'm creating profil with this items. But i have this message: *Imput file has invalid geometry* . for this time, i dont have the solution. See here the file of items in .txt and .xls format. Please help me to see the problem with the input file.
Thank you
Pointdump
Benjamin,
There's a double space in the first line of your text file.
Edit: Removing that extra space didn't work. Still have the "invalid Geometry" error.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Joe-Bouza
I’m pretty sure save as txt from Excel makes tab delimited.
Try copy the space paste to find and replace and use one space bar in replace field
Joe Bouza
Pointdump
Hi Joe,
I only found that double space in the first line of Benjamin's text file. Everything else was a single space, exactly as needed to create the Profile. I'm stumped. It should work, but yet it doesn't.
I even tried saving the Excel file as a CSV and then replacing the commas with spaces. Still didn't work.
Dave
Dave Stoll
Las Vegas, Nevada
Jeew-m
Dear Friend,
Apart from Dave's suggestion on the spacing issue on the first row there is another issue in station 8300. You have two rows for station 8300. You need to delete/modify one station and do the import. It will work.
This is how I figured it out.
Stations are in incremental order. So going down means increasing the station value. I put a simple IF function on your excel. At 8300 it says next station to 8300 is not greater than 8300. Then when I checked it is not greater than 8300 but it is equal. This has been the issue.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Pointdump
Jeewana,
Excellent! You found it! I deleted one of those stations and now it works.
Dave
Dave Stoll
Las Vegas, Nevada
