Problem after installing Russian Country Pack
nikoue
nikoue
I Install the Russian Country Pack in my civil 3d 2013 because i want to examine some styles that i saw to Youtube and like it.
I install it and a profile was created.
But after that a problem occurs in my English profile and now some names displays in Russian.
So now some Feature Line names in a corridor of one of my existing drawings opened with the english profile displays in Russian.
See the attached files.
I had this problem with 2011 when i had installed a German profile but i don't remember at all how i resolved it.
I think that there was a variable or some dll files.
Can anyone help?
Thank you.
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
YRogachev
You have to change corridor codes file C3DStockSubassemblyScripts.codes. After installation Russian Country Kit, he was change to Russian version. You can find this file here:
C:\ProgramData\Autodesk\C3D 2015\eng\C3DStockSubassemblyScripts.codes
In same folder, you can find C3DStockSubassemblyScripts_en-US.codes, with English codes. Just copy/paste contents or rename.
After that, rebuild assembly and corridor.
Igor Rogachev/ Игорь Рогачёв
BIM Infrastructure Expert / Эксперт по инфраструктурному BIM
Онлайн-курсы Civil 3D
Опыт применения Civil 3D
LinkedIn
Этикет и принципы общения Autodesk Community
nikoue
Thank you very much. I delete at all the C:\ProgramData\Autodesk\C3D 2015\eng\C3DStockSubassemblyScripts.codes File and i Left the two C3DStockSubassemblyScripts_en-US.codes and C3DStockSubassemblyScripts_ru-RU.codes.
Now if i open the Russian profile it displays Russian code names and if open the English Profile English code names.
I think that is a mistake in the installation that Autodesk must resolve.
Do you now if that install make another changes in other settings that i didn't yet see?
Also I realize that there is a CodeFileName.ini  that now refers to the Russian names. But after i made the changes i wrote above it doesn't seem to impact the names. Do you know what that is?
Thank you.
nikoue
EventViewer.jpgI just realized that the Country packs that i have installed (yes i tried some more) create another problem in civil 3d.
See the image.
Any idea?
