Civil 3D Forum
Pressurized pipe network elevation adjustment!!
1 REPLY 1
knowledgeseeker985
104 Views, 1 Reply
Hello Everyone,
Autodesk AutoCAD Civil 3D 2021.
I was assigned work that iam not familiar with for the first time. The scope of the work is to design/draft a pressurized pipe network for a lagoon cell to bypass another lagoon cell. The pipe will be temporary and will be above ground.
from my understanding the pressurized network require a surface that will be used as a way to obtain elevations (Cover). Now i cant use the existing ground as its not the best.
i can use an alignment or a feature line and create the pipe surface and use that for the pressure network, but that will require to do more work that i prefer not to do if possible.
If there a way to adjust the pressure pipe network as we do with feature lines? or is there an easier way/better way that iam not familiar with?
Thank you for your time
1 REPLY 1
Rail Community
