Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I have recently upgraded to Civil 3D 2021, and the Pipe Runs function in the Pressure Pipe Network is giving me a fit. It is quite possibly the most buggy feature I have seen Autocad release...unless I am doing something totally wrong. Our firm primarily focuses on water & sewer infrastructure; therefore, pressure pipe networks are a very large part of our workflow. Issues:
Can someone please help me resolve items 1 & 2 and offer some advice on how to use correctly for item #3? I am to the point where I just want to go back to doing manually, I would have my drawings done already.
I would start a support case to make sure that Autodesk is aware of these issues. Posting here does not guarantee that.
John Mayo
Also having these exact issues the first go at trying to use pressure pipes in 2021.
Same issue here.
Pressure Pipe runs are very unstable. Pipe runs alignments out of nowhere are somehow disconnected from the pipes, and from the profile as well.
Lots of fatal errors and crashes.
This is still happening and is very annoying. Work so many hours placing a pipe run modify all the elevations and then one day you re open the .dwg and its gone...
Hello, having the same issues and stumbled on this thread, Any updates or solution for this problem? Thanks in advance!
Pipe Runs disappearing all over the place. I just gave up on it. Its really so frustrating that Autodesk release such defective functionality.
Pipe run disappears
We ran into this (using C3D 2021) and figured out it had to do with the deflection angle between 2 pipes. If it was outside of the set "Allowable Deflection" degrees from the parts list it would break the pipe run upon reopening the dwg. This is the error we got when opening the dwg: ''Unsupported geometry changes would break the consistency of pipe run ("Pipe Run -(##'))), so the pipe run was detached from the path."
We now run a design check after doing a pipe run to see where any issues with pipe deflections are, fix them and so far seems to keep our pipe runs working.
@cyoungVTYTM Do this work on Civil 3D 2021 and 2022 versions too? No more issues with pipe runs?
@KarlHanson We just went to a 'best practice" of using design profiles for pressure pipe runs and that has helped cut down on the number of deflections that need fixed so we don't loose the "pipe runs".
@Tiago.CaldeiraPZ4FE This is also an issue with 2022.
This has happened on some of our jobs. We've abandoned pressure networks, the potential time savings is not worth the headache to the designers.
Does anyone know if the 'pipe runs deleting themselves' issue has been fixed in Civil 3D 2024?
I am not sure on 24 as we are still putting the deployment together.
I do know that in the later updates for 2022 (I assume would be included in 2023 and 24) that they fixed it so it didn't break as often and added a "Re-Link Pipe Run" tool that made it really easy to fix it if it did break.
I downloaded 2023 in hopes it would address the issue. Pressure networks are still as glitchy as ever. For smaller networks they work OK but for things like for a major water treatment plant's yard piping they are horrible. Pipe runs will automatically delete if they are too large / complex.
