Pressure Pipe Network
Hi All, I took a crash youtube course on pressure pipes yesterday and I seem to have a basic grasp of it.
I am trying to run a 36" water main and the issue I am currently having is the deflections are out of whack. In my parts list i have 1deg of allowable deflection in my pieces and elbows, but it is generating a profile with pieces that are out of spec.
I am using a reference surface I created out of a pipe invert profile that I was doing a little trial and error to get appropriate cover underground...the profile of the surface has angles that are close to meeting the deflection requirements. I have a horizontal polyline that I have at a "0" elevation, so I was hoping that the pressure pipe creator would force the pipe to be created within the allowable deflection design criteria at an offset cover not being less than 5', for example, but meeting deflections....so at some points the depth would be much greater than 5'. It seems like it just wants to ensure the 5' of cover and not really care as much about the deflection.
Can you not force this command to create a vertical profile of the pipe to be within the allowed deflection values?
I know I probably didn't explain this very well, but hopefully you get the idea of it.
