Pressure Pipe Network and Land XML
InfraChic
InfraChic
Has anyone had any success in exporting out a pressure pipe network using LandXML?  I'm running 2018.2 C3D and every time I export out any one of my many pressure pipe networks a file is generated but it's pretty much blank.  The only thing created is the standard header information.  There's no content.  I've attached it here. I've tried both LandXML 1.0 and 2.0 same thing.  I'd love some tips on how to export this out so I can send it to my subs.
Heidi B.
Infrachic.
CADmgrMike
same problem here using 2019.1.3
Mike Porter
https://provostandpritchard.com/
kcobabe
Right now the only way to do this is to switch to a 3d view and export.  If your sub needs it for Revit, their is not a really good way to export to this.  You will get most of the information, but the pipes do not show unless you do a conversion and then they don't look like pipes.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Same issue in 2021.1.
Cadguru42
C3D 2021.3 also still has this years long bug. Or as Autodesk calls them, "enhancements".
C3D 2024-2026
Windows 11
32GB RAM
llavayenMG53S
*BUMP*
We sill need it 2024
