- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Need to set light poles along road alignment.
I have txt file, that contains info of station, offset and description (light power and other info).
I can import points from file, but can I somehow attach points in specific alignment?
So I can add point label that shows current station and offset. And if I move that point it chances those values?
Is it possible with point label styles? Or is it even possible?
I need poles to be exported in 3d and I need list of poles coordinates, elevation, light power and other info later on.
So is Pipe Network of just alignment labels an option?
