I'm creating a very simple surface defined by just four points in a PENZD file. No issues uploading, creating a point group, or adding that point group to the surface definition. However, the surface renders using only three of the four points (creating just one triangle) despite listing four points in its definition. Point 2022062101 is not included. Stranger still, when I add a dummy fifth point that is simply the average of all the others, the missing point shows up, but the surface still only creates three triangles when four would be expected. I have tried manually retyping the points into a new excel file, saving as both txt and csv to eliminate any strangling data from excel, neither has changed the rendering.
The PENZD with both the four points and with a fifth point are attached. The attached drawing file has layers "2022-06-21" which includes just the four points and "2022-06-21 with dummy" which includes the fifth dummy point. Any assistance would be great. Thank you!
