Civil 3D Forum
point missing in feature line report for surfaces
1 REPLY 1
203 Views, 1 Reply
I get the surface points from feature line report menu to post process on it but when I have near vertical slopes in the feature line report some of the surface points are missing. for example one of the two points with closely distance are add to the report and one of the points are missing. if you want to use near to vertical slopes instead of walls in the reports one of the wall point are generated ( top or bottom).
I tried to change the slope to 0.01:1 and it worked for some sections I think it is related to the precision of the calculation but I can not find it. I tested the precision change for distance coordinates and ... from settings
1 REPLY 1
As you have found out, you cannot have vertical faces, they must have a slight horizontal difference from top to bottom.
Rail Community
