point display in paper space
johndehan
johndehan
I am using Civil3d 2014
The point style (PD) is not being scaled correctly in paper space. I cant get it to come out smaller.
Replies (13)
tcorey
Do the labels re-size when you zoom within the viewport (you might have to regen to get it to update)? If so, just change the label size in the label style composer.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
You can also check the scale used in the drowing propoerties. Go in the settings tab, than right click on the drawing name, then check if the scale is the same you are using in paper space.
doni49
I think the OP is talking about the Acad Point as opposed to C3D's cogo point.
What are PDSIZE & PDMODE set to?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
johndehan
no they do not change size when zooming
johndehan
Hello and thank you for your input.
I t\changed the scale to match paper space and the point style labels did not change.
johndehan
Hello and thanks for the answer. I changed the scale as suggested and it did not alter the size of the point labels in paper space.
johndehan
These are civil3d cogo points.
The pdsize is 0.5, pdmode 0
cwr-pae
Check your viewport scales. Annotation scale effects labels and other 'annotation' objects, the standard scale effects the overall scale. If these aren't both right odd things can happen.
Hi again, once you could not solve it with the scales, try now to find the text style you are using in your label, maybe the style is been set to a fix text high, try to change the text style or choose other style, like a standard one.
rl_jackson
I'm wondering if the Point Label Style is set to a FIX height vs, by drawing scale.
Rick Jackson
Survey CAD Technician VI
johndehan
The point text changes with a scale change in model space  but not in paper space
sjgoessling
Make sure the Plot Scale in Page Setup Manager is set to 1"=1' and your viewport scale is the scale it needs to be.
Steve Goessling
cwr-pae
Can you post the drawing?
