Point Codes missing from Section View
cadguy101
cadguy101
My point codes on my corridor are missing for some of the new section views I created.
The code set has the appropriate point codes labeled, but those codes are missing on my new section view, even though the corridors are the same assembly.
I have tried removing the corridor and resampling it but that doesn't help.
cadguy101
Well I found a solution, but not sure it's supposed to be this way. The sections not showing the correct codes are not at even station and I had split the region at the location of the section for it to register.
So does the corridor have to have a section at the section view to work?
nuno_dias
Did you find the problem root? or the solution to solve it?
