Civil 3D Forum
Point Cloud Lat. & Long.
23 REPLIES 23
Message 1 of 24
1283 Views, 23 Replies
Is there any way to get the Lat. & Long. from a point cloud that an Las File has been used to create a surface, so that I can line up the Bing image correctly. I have no defined object in the surface file only contours and of course the cloud points.
When I originally download all the different files I was hoping to find a shape/breakline file of sorts that would show the existing building, roads ...ect.
I think the info may be in a file that has an *.IMG extension and properties says that it is a "Disk Image File". How do I get this file to work?
2015 In Use
Dave Z.
23 REPLIES 23
Message 21 of 24
AllenJessup
in reply to: Pointdump
Use this file. I don't think the path should be any different for you. If it is do a search for the .bat file.
C:\Program Files (x86)\FWTools2.4.7\openev.bat or C:\Program Files (x86)\FWTools2.4.7\bin\openevw.bat
For more fun and giggles. Right click on the file and select Edit. This is how everything used to happen on a computer before windows. I put a link to that file on my desktop.
Allen Jessup
CAD Manager - Designer
Message 22 of 24
AllenJessup
When using gdal_translate you may need to use the -of switch. See:http://www.gdal.org/gdal_translate.html
Allen Jessup
Message 23 of 24
Pointdump
in reply to: AllenJessup
Allen,
Thank you. I finally fumbled around, found and stuck Open EV on my desktop. I opened the "img" file with Open EV and saved it as a gTiff. Then I could bring it into C3D and create a 25,000,000-point surface.
I'll keep plugging away with Microdem. It seems to be GUI, but at this point I find it completely unfathomable.
QGIS is easy. It accepts ".img" files and will re-project them with GDAL-Warp into a useable GeoTiff for C3D.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 24 of 24
AllenJessup
Dave,
Sounds like something I should check out. But our IT doesn't like a lot of programs they don't approve installed. They overlook some things I do because I'm the CAD Manager. But I don't like to push it too far.
Allen
Allen Jessup
Rail Community
