PNEZD point file format missing
camptech
camptech
For whatever reason, my employer's default Civil3D template does not come with a PNEZD point file format.  I have need to dump points out to a .csv file so that I can look at them in Excel.  While I know I can create a PNEZD point file format, it's a PITA, esp. if I end up having to do this multiple times.
Is there a way to quickly copy the default PNEZD point file format from a different .dwg, or some magic command to re-create it?
TIA.
rl_jackson
With the TOOLSPACE set to MASTER VIEW - Open a drawing with the PNEZD format in the file, make sure that the file is active (on screen) go to the TOOLSPACE - SETTINGS and drag the PNEZD format to the drawing window from the inactive file, then you'll have to scroll down to the inactive file and expand Point - Point file formats - select (make blue) and drag it to the active drawing.
Rick Jackson
Survey CAD Technician VI
camptech
Thank you!
I now do recall seeing PNEZD under Point File Formats in the Settings tab > <Drawing> > Point.  I was searching around DesignCenter and right clicking on the drawing title under the Toolspace > Settings tab.
Thanks again.  Your answer is one of the few things to have gone right in my day today.
Regards.
