Plot lines by station offset Script
Joe-Bouza
Mentor Mentor
Message 1 of 10
Joe-Bouza
I have several sanitary house connections that need to be added to the drawing.
I know all the stations and how long I want them.
How can I script this: this is a sample line station offset station offset should draw a 25' long line at station 4355.29
4355.29 0 4355.29 -25
Joe Bouza
Replies (9)
Message 2 of 10
tcorey
Do you have those data in a text file? Post it.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 10
Joe-Bouza
Hi Tim
this is raw. The station values are from record plans but my alignment stations differ slightly between manholes that I can adjust but hadn't a chance to do so yet.
Eventually they will become pipes
4569 0 4569 50
4566 0 4566 -50
4523 0 4523 -50
4521 0 4521 50
4485 0 4485 -50
4483 0 4483 50
4442 0 4442 50
4341 0 4341 -50
4339 0 4339 50
4300 0 4300 -50
4298 0 4298 50
4258 0 4258 -50
4256 0 4256 50
4213 0 4213 -50
4211 0 4211 50
4174 0 4174 -50
4172 0 4172 50
4104 0 4104 -50
4102 0 4102 50
4066 0 4066 50
4064 0 4064 -50
4025 0 4025 50
4023 0 4023 -50
3969 0 3969 50
3967 0 3967 -50
3924 0 3924 50
3922 0 3922 -50
3875 0 3875 -50
3835 0 3835 -50
3833 0 3833 50
3800 0 3800 -50
3798 0 3798 50
3756 0 3756 -50
3754 0 3754 50
3718 0 3718 -50
3716 0 3716 50
3678 0 3678 -50
3676 0 3676 50
3647 0 3647 -50
3576 0 3576 50
3511 0 3511 50
3509 0 3509 -50
3464 0 3464 50
3462 0 3462 -50
3444 0 3444 -50
3442 0 3442 50
3387 0 3387 -50
3362 0 3362 -50
3342 0 3342 50
3328 0 3328 -50
3306 0 3306 -50
3304 0 3304 50
3282 0 3282 -50
3267 0 3267 -50
3265 0 3265 50
3217 0 3217 50
3215 0 3215 -50
3172 0 3172 -50
3170 0 3170 50
3075.5 0 3075.5 -50
3038 0 3038 -50
3036 0 3036 50
3007 0 3007 -50
3005 0 3005 50
2979 0 2979 50
2977 0 2977 -50
2952 0 2952 -50
2950 0 2950 -50
2914 0 2914 -50
2912 0 2912 50
2895 0 2895 50
2866 0 2866 -50
2864 0 2864 50
2815 0 2815 -50
2813 0 2813 50
2757 0 2757 -50
2755 0 2755 50
2714 0 2714 -50
2711 0 2711 50
2625 0 2625 -50
2623 0 2623 50
2588 0 2588 50
2563 0 2563 -50
2550 0 2550 -50
2548 0 2548 50
2525 0 2525 -50
2510 0 2510 50
2508 0 2508 -50
2475 0 2475 50
2473 0 2473 -50
2444 0 2444 -50
2442 0 2442 50
2409 0 2409 -50
2407 0 2407 50
2363 0 2363 -50
2361 0 2361 50
2324 0 2324 50
2322 0 2322 -50
2290 0 2290 -50
2288 0 2288 50
2267 0 2267 50
2265 0 2265 -50
2177 0 2177 -50
2175 0 2175 50
2144 0 2144 -50
2142 0 2142 50
2113 0 2113 -50
2111 0 2111 50
2079 0 2079 -50
2077 0 2077 50
2043 0 2043 -50
2041 0 2041 50
2012 0 2012 50
2010 0 2010 -50
1972 0 1972 50
1969 0 1969 -50
1942 0 1942 -50
1939 0 1939 50
1917 0 1917 50
1914 0 1914 -50
1887 0 1887 -50
1885 0 1885 50
1868 0 1868 50
1865 0 1865 -50
1815 0 1815 50
1812 0 1812 -50
1729 0 1729 50
1726 0 1726 -50
1691 0 1691 50
1688 0 1688 -50
1642 0 1642 50
1636 0 1636 -50
1618 0 1618 -50
1597 0 1597 50
1594 0 1594 -50
1540 0 1540 -50
1537 0 1537 50
1507 0 1507 -50
1504 0 1504 50
1472 0 1472 50
1469 0 1469 -50
1438 0 1438 -50
1435 0 1435 50
1377 0 1377 -50
1374 0 1374 50
1355 0 1355 -50
1352 0 1352 50
1332 0 1332 -50
1329 0 1329 50
1320 0 1320 -50
1308 0 1308 -50
1305 0 1305 50
1276 0 1276 -50
1273 0 1273 50
1244 0 1244 -50
1241 0 1241 50
1211 0 1211 -50
1208 0 1208 50
1188 0 1188 -50
1185 0 1185 50
1163 0 1163 -50
1160 0 1160 50
1132 0 1132 -50
1129 0 1129 50
1109 0 1109 50
1106 0 1106 -50
1082.7 0 1082.7 -50
1076 0 1076 -50
1072 0 1072 50
1049 0 1049 50
1039 0 1039 -50
Joe Bouza
Message 4 of 10
brian.strandberg
removed.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 10
TerryDotson
Use Excel or an ASCII editor to create a SCRipt file.  The built in 'SO (Transparent Station Offset) command will translate the station/offset values to coordinates within the LINE (or whatever) command.  Be aware that any tool (like _AeccCreateNetworkFromObject) that shows a dialog will bring a script file to a halt.
Looks like a good area for some well applied automation.
Message 6 of 10
Joe-Bouza
Hi Terry
I did try that to no success
Joe Bouza
Message 7 of 10
tcorey
 reformatted the file to make a csv. This code reads a csv and draws lines. It's not pretty, but it get lines on the page for you. I don't know what those two that drawing parallel to the alignment are. Anyway, this might help you move the project along.
(defun c:go ( / aln fl ln sta1 off1 sta2 off2)
(vl-load-com)
;select existing alignment
(setq aln (vlax-ename->vla-object (car (entsel "\nSelect Alignment: "))))
(setq fl (open "E:\\_Support\\_Usenet\\231212 LISP to draw at StaOff\\pipes.csv" "r"))
(setq ln (read-line fl))
	(while (and ln)
		(setq sta1 (substr ln 1 4)
		      off1 (substr ln 6 1)
			  sta2 (substr ln 8 4)
			  off2 (substr ln 13 3)
			  (vlax-invoke-method aln 'PointLocation sta1 off1 'x1 'y1)
			  (vlax-invoke-method aln 'PointLocation sta2 off2 'x2 'y2)
			  (vl-cmdf "LINE" (list x1 y1) (list x2 y2) "")
	);end while
	(close fl)
	(princ)
Tim Corey
Redding, CA
Message 8 of 10
tcorey
Hi @Joe-Bouza ,There's an error in my code. I didn't look closely-enough at your data. It initially appeared that all the stations were four digits, no decimals, but I found the source of the horizontal lines. There are a couple stations that go to a tenth. If you need this lisp to process those two lines correctly in the routine, I will have to change how I read each line of data. I was just telling it start at character x and go for y characters. It works to capture 4 characters for the station, except for those two points.
Tim Corey
Redding, CA
Message 9 of 10
Joe-Bouza
Much appreciated Tim @tcorey
excellent.
Joe Bouza
Message 10 of 10
Joe-Bouza
Hi Tim @tcorey
the data I gave is raw and I have been reformatting and we go to two decimals. I done want to burden you but If you could read two decimals that would be great. I am guessing I would tweak the file path and name?
Should I make it a <>.lsp file or can I paste to command line?
Joe Bouza
