Civil 3D Forum
Pipe style in profile
8 REPLIES 8
Message 1 of 9
592 Views, 8 Replies
Trying to make some changes to improve reading.
The pipes are going to center of structure and would like to change the appearance but maintain the lenght to the center or in last case to the structure wall.
The image explains the 'problem'. Red line should be the correct appearence
There is a way to correct the position?
Thank you
8 REPLIES 8
Message 2 of 9
Joe-Bouza
does your style show the outside wall?
Joe Bouza
Message 3 of 9
in reply to: Joe-Bouza
Yes, the style shows the outside wall, is the unique line visible in pipe profile style.
Message 4 of 9
Jay_B
We show our Pipes to outside walls in the Pipe Style too.
It looks like your structure "Floor Thickness"  may be set to 0 or close to it.
If the "Floor Thickness" is displayed the Red Lines you show should be fixed.
Structure properties_Part Properties Tab_slab thickness to check this setting.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 5 of 9
troma
in reply to: Jay_B
Jay,
How thick do you have to make the floor for this to work?
My problem is that we need to draw the inside of the structure, not the outside.  So far our solution is to have very thin walls and floor; but obviously this leads to the problem with the pipes attaching to the centre instead of the walls.
Mark Green
Working on Civil 3D in Canada
Message 6 of 9
Jay_B
in reply to: troma
Ours are set to 0.67 or 1 Imperial units. (see attached).
C3D 2018.1
C3D 2016 SP4
Message 7 of 9
troma
in reply to: Jay_B
I guess it's 3.011x10^23 of one or half a mole of the other.
We can't show sumps like that in profile view.  In the past we've put wipeouts on all our manholes for this.  It's either that or trace over everything with plain old lines, and turn off the style of pipes & profiles.  We can't win really; until we get the ability to draw the inside walls of structures and turn of the outside wall.
Mark Green
Message 8 of 9
Jay_B
in reply to: troma
When we first switched to C3D we had a lot of comments regarding the floor thickness being shown. Once we got used to seeing it it wasn't a big of a deal. (my standard for answer is it's representing everyhing in 3d)
I've been using the Wipeout / Masking technique for the "Aprons" or "Outlet" structures.
Hopefully these will become better to work with in the future.
End up drawing aprons manually because they never look desireable in profile.
C3D 2018.1
C3D 2016 SP4
Message 9 of 9
in reply to: Jay_B
so, you have the same 'problem', though it was exclusive from my style.
Jay if you drawq the interior lines the result will be aproximally the same with floor thickness ou sump drop, whats the bennefit?
Rail Community
