Pipe networks - parts list and parts catalog
steveblurton8276
steveblurton8276
I commonly switch between 2 different parts catalogs depending on projects worked on.
When I switch between catalogs for some reason it doesn't change to the matching parts list.
When i go to start to make a network i get this message :-
Catalog
Parts list
The pipes list should only have 3 or 4 entries and these aren't correct.
What am i missing to be able to either select the correct parts list or the reason it doesn't select the correct one?
Thank you in advance
Replies (9)
rl_jackson
Version? Has the Parts List been carried from dwt to dwt.... Have you tried recreating them in the dwt for your current version?
Rick Jackson
Survey CAD Technician VI
h.castrocelani
Hi Steve,
This is a very obvious question but have you tried to regen the part catalog after setting the part catalog?
m_kingdon
This might not answer your question directly, but could you just make a combined catalogue so you don't have to keep switching?
Mike Kingdon
Civil 3D Zealot
steveblurton8276
Hi, Thanks for replying.
Yes, I've tried that but it didn't work.
steveblurton8276
It's versions 2019 and 2020.
How do you mean "recreating them in the dwt "
steveblurton8276
I can, but i just needed to know if I was missing some command that would enable me to pick the parts list, as it doesn't seem to change with the catalog.
Cadguru42
The parts list is a part of the DWG. The catalog is an external system that a parts list uses to create the part in the DWG. Switching catalogs does not change a parts list. After you switch catalogs you have to pick a parts list from the Create/Edit pipe network that uses the same catalog that was associated with the current parts list.
C3D 2024-2026
Windows 11
32GB RAM
steveblurton8276
Thank you for replying.
I think I've managed to sort something out.
When I change catalogs, if i then create a new parts list and pick items from my required catalog when i create my network i can use the parts i've picked. All good.
Should I create a parts list for all additional catalogs I'm likely to use in my template files?
I found that "After you switch catalogs you have to pick a parts list from the Create/Edit pipe network" There was no list for the new catalog, hence I tried the above.
Is the method I'm doing correct or am I still missing something? Sorry if I am being a little dim with this.
Cadguru42
Best practice is to have a template where you've created parts lists using the catalogs needed for each. That way you've always got a parts list of the parts needed. For instance, have a sanitary pipe parts list created using the correct pipe catalog. Then when you need to create a sanitary pipe, you just make sure that the network you're editing has that part list selected.
C3D 2024-2026
Windows 11
32GB RAM
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
