Dear Autodesk,
We use Data Shortcuts for all our pipe networks.
Would you please change the menus for Pipe Network functions so that "Promote" isn't directly next to "Synchronize" and also add a warning or more warning messages for if someone accidentally selects "Promote" instead of Synchronize?
We synchronize our pipe networks often as we're working in a project. Between existing cad files, proposed cad files, pipe network cad files, plan & profile sheet cad files - pipe networks can be Synchronized a lot. We use the "Promote" command on pipe networks sometimes, but very rarely.
Annoyingly, we are having too many problems where pipe networks accidentally get Promoted instead of Synchronized, and it's a time-consuming mess to clean up once we've realized it's happened.
We've got summer interns accessing CAD files and it happens more than one would think.
The command options for Synchronize vs. Promote Pipe Networks could be moved AWAY from each other on the menu. Also, adding Warning message(s) when "Promote" is selected would be good. Are you sure you want to Promote? Are you sure?? Oops, darn I just wanted to Synchronize. Good thing that warning message popped up! I thought I'd selected "Synchronize" phew.
But not really Phew because a warning message(s) for Promote is needed. This is happening far too often & creating big messes to clean up.
Thanks if you can help Autodesk. Or, is there advice to avoid this potential Accidental Promote vs. intended to synchronize mishap?
