Pipe Network - Structures not inserting
nnikula
nnikula
Hey all! I was having a little trouble trying to use one of my custom made parts in the pipe network. For some reason, since updating to 2020, i havent been able to add in any of my newer parts that i have made in my drawing. Clearly it is in the network, but for whatever reason, i am unable to select in in the drop down list in order to actually insert it into the drawing. If you have any ideas on a solution, please do share! Thanks in advance!
Karadzhaian_Eduard
first try to delete family with all dimensions from part list.
Then reimport it again there.
And also try to click to "+" in the list when you want create a structure in a drawing 🙂
If you want to regen part catalog you must close all active functions.
Eduard Karadzhaian
Senior Civil Infrastructure Engineer
Blog| LinkedIn| E-mail| Youtube|
nnikula
I think you solved the mystery! I went to check in my part builder, and the shape wasn't listed. I must not have copied it over from 2019 C3D. Thank you for the help!
SOLUTION: Check your part builder and make sure you bring in your previous made parts from different software versions.
Karadzhaian_Eduard
@nnikula,
I'm glad to hear that your problem solved.
Thank you for your research in Part Builder.
Eduard Karadzhaian
