Civil 3D Forum
Pipe network Profile Labels moving themselves when switching from Model Space to Paper Space
3 REPLIES 3
eacostaD59UH
611 Views, 3 Replies
This has happened to me in Civil3d 2022 as well as now 2023. I am creating plan sheets for a design with a pipe network, and my labels are moving themselves (pictured) when I switch between model space and paper space. The issue does persist through plotting (not resolved by simply plotting).
So far I have tried:
Pinning the labels
Editing the label style (I created a new label style to test this)
Assigning a reference alignment
I suspect the issue is either tied to the label style or a spatial issue with the pipe network. Interestingly, there is a workaround. If I save, and then CTRL Z it will reset the labels on my paper space and I can plot (regenall does not work). I would like to be able to avoid having to save and unsave to reset my labels.
Thanks in advance.I switch from Paper Space to Model Space and the labels do this.I switch from Paper Space to Model Space and the labels do this.CTRL S -> CTRL V is the workaroundCTRL S -> CTRL V is the workaround
3 REPLIES 3
SoaresASBCAD
in reply to: eacostaD59UH
eacostaD59UH
in reply to: SoaresASBCAD
Thank you so much! This worked for me. I'll add the fix below in case anyone else experiences this.
Issue was with my profile style.
Fix: Toolspace - Settings - Profile View - Profile View Style - Grid-Axis offset (plotted units)
By default our Grid Axis offset was not 0.0000" (we were 0.300"). I set to 0.000" and the problem was fixed.
Thanks again!
cgerk
This problem has literally been around for decade+.
Autodesk, do better.
Rail Community
