Pipe length and grades not correct
Message 1 of 9
Has anyone had problems with the lable styles not giving the correct length or the correct  invert elevations in c3d 2018
Dave Z.
Replies (8)
Message 2 of 9
Joe-Bouza
What does the style say to do? Expressions?...
I always lane and compute center structure to center structure and label accordingly
Joe Bouza
Message 3 of 9
Label is set for 2d c/c. Invert in and out  in one location is off by 0.05
Message 4 of 9
Joe-Bouza
Sometimes when I get really **** about the numbers I’ll force the manhole separation to be exact.
if you are calculating based on Len = 287 feet but they are actually 286.932. I’ll draw a 287 foot circle a make it right.
Maybe that’s what you have?
Joe Bouza
Message 5 of 9
wfberry
Are you saying that the invert elevations as shown in Prospector --> Networks --> Pipes   do not match the labels?
Bill
Message 6 of 9
Bill
The labels inverts match.
When the engineer back checks the invert elevations using the length and grade he say's the invert elevations are not correct.
I will see if I can get an example dwg  uploaded.
Message 7 of 9
no go on the file upload.
If we take
Pipe Length x %grade = Drop
        The two drops do not match. They are off by several hundredths
Invert In Elev. - Out Elev. = Drop
Message 8 of 9
wfberry
You can have the program do more than "version".
Using the standard C3 D method, your pipe length is measured from CL Structure to CL Structure.
Bill
Message 9 of 9
Joe-Bouza
force the distance between manholes to be exact
Joe Bouza
