Announcements
Pipe Labels to show Chainage
L3GO-Ed
L3GO-Ed
Hello Experts,
It is possible to depict the Chainage location of a pipe in the Pipe profile label? How would one go about it?
Ediriisa
Jeff_M
The pipe label style text components have the Start/End station/chainage properties that can be added to the style. Is this not what you want?
Jeff_M, also a frequent Swamper
allanthebruce
Hi there, this is what I am after but cannot find this style in the text component editor? There is no chainage option at all? any help appreciated.
Allan
michael
As Jeff said, in the pipe label composer there are two components: Pipe Start chainage / End chainage. If used the reference alignment must be set in the pipe part.
Edit the label and in the contents you will find these listed.
Another useful function is to use reference text in the label, you can add a reference alignment to the label and pull the station at any location based on the labels location.
Mike
MMcCall402
It should be available in the text component of the pipe label.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
