Pipe Label not recognizing material
dbartholPQYPW
dbartholPQYPW
Pipe label is not recognizing PVC and HDPE. It only recognizes DI.
brian.strandberg
I would make sure that the correct materials are defined in your catalog.  Without the catalog I can't test the drawing properly.
Personally, I prefer using the Pipe Description to fill out the pipe type.  I can change Descriptions on the fly, with materials I need to take time to set them up in the Catalog.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
dbartholPQYPW
Thank you. After posting, I check my ability to change it in pipe properties and was successful.
