Civil 3D Forum
Pickfirst not working 2018 Civil 3D
6 REPLIES 6
733 Views, 6 Replies
Pickfirst valve not working, although it is set to 1. Pickadd, qaflags and all other variables are set correctly.
Anytime I select a feature line, surface, profile, cross section, then choose a command from the ribbon bar, it drops the command and I must re-select the items. Any help would be greatly appreciated, its driving me crazy!
6 REPLIES 6
AlmasSuljevic
Do you happen to have Raster Design installed too? Do you have ability to select with SHIFT+CLICK? Can you check MAPIOPTIONS and IOPTIONS settings to see if they are allowing you to make selections?
  1. In command line run the IOPTIONS
  2. Go to the User Preferences tab
  3. Uncheck the toggle Shift+Left Click Image Select
  4. Run MAPIOTIONS command
  5. Go to General tab and uncheck “Shft+Left Click Image Select"
Let me know if this helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
wfberry
in reply to: AlmasSuljevic
Gee Almas:
I don't recall "seeing" you in some time.
Bill
Unfortunately, that didn't work. But yes, Raster Design is installed as well.
AlmasSuljevic
Will setting PICKADD to 2 (default value) make any difference? So when you are trying to select can you use "R" for remove or "A" for add? Is that being ignored too?
Almas Suljevic
Pickadd is set to 2 already.
Cleaning and deleting the registry files worked temporally, but the next day I had to completely uninstall Autodesk and reinstall.
Rail Community
