Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Part not working when new size added
Hi All,
I'm quite new to Civil3d and I was just trying to add a new size to the default family "AeccCylinderJunctionStructureNF_Metric". I don't experience any problems using Part Builder but once back in Civil3d when I try to use that part (with any sizes, previous or added ones) seems not to work properly.  Inner Structure Diameter value is "0" as well as Insertion Rim Elevation.
Have anyone experienced this problem before?
Yare
cwr-pae
After modifying parts, they have to be reloaded and you should also test them.
AeccuContentBuilder, select the catalog name in the dialog box and then find the icons for "Catalog Regen" and "Catalog Test". Any errors encountered by the test will show after pressing F2 key.
Other than that, you must have some bad parameter or format of parameter in the part .
