Part Builder for Caps
apweng
apweng
Hi there,
Any suggestions on how to use part Builder to model caps on pipes?  I'm most curious to see if PB can automatically size a cap to show in profile view based on the diameter of the pipe.
Thanks!
Andrew
cwr001
To my knowledge that's not possible, unfortunately.
I think pipes only allow for sweeping profiles that are true for the whole length of the pipe.
matt_anderson_pe
You would need to build a Structure > Inlet/Outets type that matches the cap.   You migth start with the End Section Round structure and strip whats not needed.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
