Civil 3D Forum
Osnaps won't work on corridors items
12 REPLIES 12
Message 1 of 13
kssnuggle
578 Views, 12 Replies
When I try and add plan notes and dimensions to the plan sheets  the osnaps will not work on the corridor items. It doesn't matter if I am in paper or modelspace.
The sheets were created through plan production tools and are data linked.
Vrs 2018 in use
Dave Z.
12 REPLIES 12
Message 2 of 13
rl_jackson
in reply to: kssnuggle
Have you tried extracting the object in question or create a corridor lable for it?
Rick Jackson
Survey CAD Technician VI
Message 3 of 13
kssnuggle
in reply to: rl_jackson
What I am wanting to do is add a dimension string perp. to the centerline of the corridor. in paper space so that I can show the width of the roadway in relationship to the right of way. Depending on the project we sometimes show a dimension for the width of entrance curb for drives or parking entrances. parallel to the alignment.
I can not snap to anything with the dimension  commands or the leader commands.
I should not have to add feature lines that muck up the files with duplicate elements just so that I can add the above items. This problem has persisted since 2011 maybe sooner and they still have not fixed it. Why ?  What's your excuse autocad Let's hear it.
Dave Z.
Message 4 of 13
Joe-Bouza
OSNAPS don’t work on many c3d objects but maybe you can try .xy perp enter 0 for z
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 5 of 13
tcorey
Set OSNAPZ to 1 before performing the command.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 6 of 13
kssnuggle
in reply to: tcorey
Typing "osnapz 1". Did not work.
Can someone from Autodesk chime in and explained why this has not been fixed?
You are placing the cadd operators at big disadvantage by not fixing this so they add the required plan/construction notes.
Dave Z.
Message 7 of 13
kssnuggle
Autodesk can you respond to this thread?
Message 8 of 13
Neilw_05
I'm resurrecting this thread just to emphasize another one of the headaches and frustrations that come with using corridors for grading. Inevitably you are going to be using featurelines to fill in the gaps, nooks and crannies that corridors don't handle well. Those FL need to snap to the edges of the corridor. Can't do it. You have to resort to construction lines or other workarounds.
Using corridors for grading SUX.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 9 of 13
cwr-pae
in reply to: Neilw_05
I don't understand the can't do part of your post. I snap FLs to corridors everyday. Its how I "fill in the gaps, nooks and crannies" mostly with corridor targeting.
Message 10 of 13
Neilw_05
in reply to: cwr-pae
Near snaps work. End point snaps? Can you snap to the end points of a dead end corridor? I am not extracting featurelines.
WIN 10 64 PRO
Message 11 of 13
cwr-pae
I just show/display the top level FLs (not extracted) in the corridor and I can end snap snap to them. I can also snap to corridor lines at assembly insertion stations. To make sure I have the elevations right I switch to one of the preset isometric views. If I have to FLs sharing end points I have to move all but one to the side (set rebuild to manual) then move one and reattach the others. It takes some getting used to but can be done and works well, sort of.
Message 12 of 13
Neilw_05
I'll check my code set. Thanks for the tip.
WIN 10 64 PRO
Message 13 of 13
Neilw_05
After all these years this topic finally has a solution. It's all about the code set.
WIN 10 64 PRO
Rail Community
