Open Channel Corridor surface extending after the target surface
Sinoj.Ravindran
Sinoj.Ravindran
I am working with an open channel surface modelling with corridor using daylight LinkSlopeToSurface.
While checking the channel section after creating the surface from the corridor, it shows that the daylight is extending after hitting the target surface !!! Tried with overhang correction but result is the same.
What may be the reason...???
Attached the image of corridor and sections.
Red dotted line is my target surface abd blue is the channel surface.
Udo_Huebner
What is the unexpected issue? Better upload your DWG, so we can examine your problem.
Gruß Udo Hübner (CAD-Huebner)
BrianHailey
When I've seen this in the past, it's typically caused by the corridor surface not having a boundary. Check your surface definition and make sure it has a boundary applied correctly to it.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Sinoj.Ravindran
Thanks for the quick fix...!!! the boundary was the issue and fixed.
