Open Channel Corridor Intersection
ahmedramy69
ahmedramy69
Hi all , wish you are fine . I'm trying to make a curved merging between these two open channels .In fact , they have different bed levels as well as different side slops , bottom widths . I splitted the bigger channel in two regions , split occurs at the intersection point .I tried also using intersection wizard , but it overwhelmed me and at the end it was to no avail .
Here are some screenshots :
c3d 2020 dwg attached
Smaller Channel AssemblySmaller Channel AssemblyBiggerChannel AssemblyBiggerChannel AssemblyThe intersection in Plan VeiwThe intersection in Plan Veiw
Mike.M.Carlson
I would try a different approach and try to focus on daylighting the smaller channel to the eastern flowedge of the larger one at the red dot (please see below).  Once the smaller flowline matches the larger flowline edge, find the surface overlap between the smaller channel's outside slopes/berms with the larger channel outer daylight slope (yellow arrows).
So rather than trying to merge these 2 corridors into a single corridor, treat them separately with separate corridor surfaces.  Then do the overlap evaluation and create a "composite" surface that has the bigger corridor with the clipped "smaller" channel corridor surface "pasted" in.  I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
ahmedramy69
Thanks Mike for elucidating such details , i will try you solutions then get back to you .
