I don't know of any specific one. But check if you think any of these might help.
https://www.google.com/search?rlz=1C1EODB_enUS572US573&biw=1581&bih=1000&tbs=qdr%3Ay&tbm=vid&ei=aX3I...
One of the first things you have to decide is if you want to do everything in Civil 3D, import a Field Book file and keep your point in a Survey Database using Survey Points. Or, if you want to do the adjustments in your data collector and export a PNEZD file to import as Cogo Points. Survey Points and Cogo Points follow different rules. Survey points are stored in an external database. Cogo Points are stored in the drawing.
Allen Jessup
CAD Manager - Designer
