I am having challenges installing Civil 3D 2020 from the normal online installer. The installation has failed a number of times and I was directed to use the browser download. However, the file I downloaded "Autodesk_Civil_3D_2020_English_Win_64bit_dlm_001_002.sfx" did not work as my system reported that there is at least one other file that is missing. Can someone tell me how I can download the missing file(s) so I can extract and install the application?
Thanks.
Solved by DarrenP. Go to Solution.
thats because you only downloaded 1 part of it read the file name
you need to download the 2nd part turn off your pop up blocker & try again
DarrenP
