Object Snaps Automatically Turning Off
Message 1 of 13
After running the line by bearing command, all of my object snaps are automatically turned off.  If there a fix for this issue.  Others currently, nor I in the past, has ever had this problem. PLEASE HELP, its bugging me!
Replies (12)
Message 2 of 13
tcorey
You didn't mention your version. It works correctly in 2018.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 13
Sorry, I thought it put it in for me.  I am using AutoCAD C3D 2016
Message 4 of 13
Jemauk
This issue just started happening at one of the stations here. That station is running C3D 2018 and hasn't had that issue until today. And line by <whatever> command is causing the issue. Any one found a solution?
Joe
Message 5 of 13
OliverE
I'm experiencing the same issue with certain commands in C3D 2018. Object snaps automatically turning off and resetting to zero.
Any fixes to this issue?
Cheers
Message 6 of 13
m_kingdon
I didn't think this was an error?  More of a programing choice to disable object snap during commands where general object snaps would be unhelpful.  In these command I always use shift + right click to bring up the OSNAP window and specify the object snap that I need.  After the command is finished my objects snap settings return to normal.
Mike Kingdon
Civil 3D Zealot
Message 7 of 13
OliverE
Do you know of a way to switch this programming choice off? Because it's bloody annoying. The most recent command it happens with is MVSETUP when aligning viewports. Object snaps are required for this command. Happens with others too but can't recall which ones.
Cheers
Message 8 of 13
m_kingdon
Try the OSNAPOVERRIDE command
Mike Kingdon
Civil 3D Zealot
Message 9 of 13
OliverE
Thanks but didn't solve it.
Message 10 of 13
m_kingdon
This topic seems to have been discussed at some length here:
https://forums.autodesk.com/t5/autocad-p-id-forum/object-snap-settings-change/td-p/2689425
I am assuming you are experiencing the same issue.  Does shift + right click bring up object snap options?  Is this not a suitable workflow?
Mike Kingdon
Civil 3D Zealot
Message 11 of 13
abattagliaN7ME
Community Visitor
Community Visitor
Mine is now doing the same thing, and i'm running C3D 2020.
Message 12 of 13
kkuecker26
I am in 2022 and the same thing happens to me when I am in the BD line command.  SUPER annoying.
Message 13 of 13
nusouthsc
Its a known issue that is incredibly annoying. I am a surveyor and I compute plats everyday using the Bearing/Distance command. Every once in a while it works but 98% of the time I have to go back and individually turn my snap preferences back on. I so wish they would fix it.
Josh Ellis
Nu-South Surveying
