Object reference not set to an instance of an object
aedwardsQM7YG
Observer Observer
aedwardsQM7YG
Observer
Observer
Whenever I try to open certain files in civil 3d it'll pop up this message and it will keep re-appearing after I click continue which blocks me out of the program.  Here is the error message that pops up:
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.LayerManager.LayerManagerControl.UpdateConfiguration()
at Autodesk.AutoCAD.LayerManager.LayerManagerControl.UpdateLayerManager(RestoreType eRestore, Boolean bForce)
at Autodesk.AutoCAD.LayerManager.CommandCatcher.UpdateOnIdle.OnIdle(LayerManagerControl lmc)
at Autodesk.AutoCAD.LayerManager.LayerManagerControl.Application_Idle(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Core.Application.raise_Idle(Object value0, EventArgs value1)
at Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
Nilesh_Chaudhari
@aedwardsQM7YG ,
Did you try Purge and Audit?
Nilesh Chaudhari
Product Support Specialist
aedwardsQM7YG
Observer
Observer
It wont allow me to use commands.
Update: I've found the issue is caused when the "Layer Properties" button is clicked in the toolbar or when you open up the new layer property palette.
mzjensen
I just started getting this error yesterday as well. Currently only happening on a single drawing, not all of them. When I open the culprit drawing, it gets stuck in an infinite cycle of unhandled exceptions, so I have to force quit via Task Manager. The only thought I have is that this drawing has a reference template attached.
When I try to Recover the drawing, there are a few errors that it finds and fixes. But the unhandled exceptions continue to occcur.
Zachri Jensen, PE   |
tcorey
If you create a new drawing, are you able to INSERT the problem drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
mzjensen
@tcorey yes, that works.
Zachri Jensen, PE   |
mzjensen
The issue was solved for me by uninstalling the 2020.5 update. Sounds like it is pretty buggy.
https://forums.autodesk.com/t5/civil-3d-forum/civil-3d-2020-5-update-is-on-hold/td-p/9788841
Zachri Jensen, PE   |
