As per the thread title,
If I have a Civil 3d created object such as a pipe (drainage) network , then in the properties box there will be a "Name" and "Description" assigned to the objects in modelspace.
However, what if I wanted to have a "Name" and "Description" added to a basic 'solid' object (say for example I extrude a rectangle) , by simply drawing a rectangle and then extruding it up some distance?
How do I get the "Name" and "Description" fields to appear in the properties box of such objects?
Solved by MMcCall402. Go to Solution.
Solved by neilyj666. Go to Solution.
Some screenshots may help with this one...
Two images attached.
{Pipe network properties box] and [3d solid properties box]
Is there any way to get the two highlighted fields ("Name" and "Description") from the [pipe network properties] in to a properties box for a basic solid object created from extruding a rectangle?
Such that I could then enter a name and description relating to the extruded rectangle.
You will need to add Property Set Data to these objects - but it will probably a bit manual rather than automated
Using Civil 3D Property Sets to add extended attribution to ANY object. - YouTube
neilyj (No connection with Autodesk other than using the products in the real world)
