Nvidia M3000M does not meet the recommended criteria
After checking the optimal system requirements and as far as I know, the NVidia M3000M meets the recommended requirements for Autocad Civil 2016 Metric.
However, at the startup of Autocad 2016 Metric, we got the message NVidia M3000M does not meet recommended criteria for autocad 2016.
Anybody knows what can be the reason?
All information welcome.
Autocad is running on Windows 7 Professional 64bit
System specs:
· HP HP ZBOOK 17 G3 MOBILE WORKSTATION
· CORE I7 6820HQ / 2.7 GHZ
· WIN 7 PRO 64-BIT
· 32 GB RAM
· 512 GB SSD HP Z TURBO DRIVE
· 17.3" IPS 1920 X 1080 (FULL HD)
· QUADRO M3000M
Thanks in advance!
Inline afbeelding 1
AllenJessup
It doesn't appear on the list -http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...
That may just mean it hasn't been tested.
Allen Jessup
CAD Manager - Designer
Hi Ellen,
Thanks for your reply.
I may be wrong, but it looks like I see the M3000M in the list you mentioned as being tested and meets the minimum requirements.
Luckily, I started up Autocad 2017 and all looked fine here. The program adjusted the setting of the graphic card.
Since then Autocad 2016 also doesn't mention it anymore.
We hope everything will work smooth now!
AllenJessup
Good catch. I'd seen the 3000m but missed the M300M. It should be fine. It looks like a good card.
Allen Jessup
