Not creating breaklines before and after curve along existing survey figures
andrew_mcconkey
Observer
andrew_mcconkey
Observer
Observer
I recently change my survey figures around curves from BCPC BC OC BC PT to BC BC OC BC and it creates much better survey figure shapes around curves as long as the BC OC is located along the mid point of the curve. My problems is that when I go to create breaklines my survey figures before and after the curve are not used as breaklines even though Civl 3d says they are. You can see from my picture below what is happening.
 Has anyone experience as similar issue and know a fix for this?
thomas598brown
Community Visitor
Community Visitor
Hello @andrew_mcconkey,
I recently changed my survey figures around curves from BCPC BC OC BC PT to BC BC OC BC and it creates much better survey figure shapes around curves as long as the BC OC is located along the midpoint of the curve. My problem is that when I go to create break lines my survey figures before and after the curve are not used as breaklines even though Civl 3d says they are. You can see from my picture below what is happening. Whataburger Customer Survey
Best Regards,
Thomas Brown
rl_jackson
What version of C3D are you experiencing this in?
How are you added the figures to the surface?
I've personally not seen this issue, but some of the issues that will cause it are adding the points to the surface that our also used to define a figure. Only add points that don't define figures.
Rick Jackson
Survey CAD Technician VI
andrew_mcconkey
Observer
Observer
@rl_jackson
This is version 13.5.211.0 CIVIL 3D 2023.1
The figures are added to the surface by right clicking figures in the survey tab (toolspace) and selecting create breaklines.
What do you mean by "adding the points to the surface that our also used to define a figure. Only add points that don't define figures"?
rl_jackson
So, I create Figure Queries and Point Queries based on the figure being defined as a breakline (checked yes) and Points that are not linework (ground shots, manholes etc... ) get added to the surface by a separate query, all of this is done in a separate drawing that has nothing but the surface in it. I don't even add the figures to the drawing. I use this drawing as my data reference for all other drawings. (I've attached sample queries in the zip file for reference.)
When I say only add points that don't define figures, I'm saying I don't add the BC points the surface since I already have the BC figure defining the breakline in the surface. By adding the point to the surface as well as the figure it's sort of a double up and in some cases a double negative. This is what I believe you're seeing in your surface but without the data can't say for certain.
Rick Jackson
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
