New polyline at relative angle
Simon_GustafssonC6JJB
Hello! I'm quite new to CAD and I have a question. I have a polyline running at a certain angle. If I want to create a new polyline at one of its endpoints, or add a vertex, either is fine, at a angle relative to the polyline, how do I do that more easily? Using f10 I can snap to angles but they are relative to the coordinate system, not the original polyline. Using the extend reference line I can calculate what angle is 180 degrees relative to the polyline and calculate my wanted angle from there but it seems needlessly complicated.
See image below. How do I create this 90 degree angle more easily?
Thank you!
Pointdump
Hi Simon,
Welcome to the Autodesk Forums.
You can use Create Line by Deflection.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
AllenJessup
Create Line by Angle Distance could work too. Depending on what information you have. In the image @Pointdump posted. You'll notice at the bottom it shows 'DD. That's  a Transparent command and can be called within another command. So you could start the Polyline Command and then enter 'DD for deflection or 'AD for the angle.
Allen Jessup
CAD Manager - Designer
Hello and thank you for your replies. In both 'DD and 'AD it seems I'm unable to specify the exact angle I want, I have to select it using the cursor? This is how the input looks like for me
I can only input the coordinate of a point, not the angle. Also, can I change the unit of the angle here? If I enter units, my units are set to degrees, not grads.
Thank you!
Pointdump
Simon,
You need to use Grad units for angle? You'll set that in Drawing Settings >> Ambient Settings >> Angle.
I tried just now to Create Line by Deflection, and I can't get it to work. I'll nose around and see what I'm missing.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Simon,
OK, I see now how >>>Line by Deflection<<< works. You can enter the angle either in the command line or use Dynamic Input.
Dave
Dave Stoll
Las Vegas, Nevada
Thanks Dave, that did the trick!
