New Model Viewer not displaying Contours
klugb
Advisor Advisor
klugb
Am I missing something because I can't display my contour lines in the Model viewer?
You can display the surface if the triangles are on, but you can't see the contours and if you turn off the triangles you see nothing. You can see them in the older object viewer.
Object viewerObject viewerModel viewer with trianglesModel viewer with trianglesModel viewer without trianglesModel viewer without triangles
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2026
Win 11 Enterprise, 64-bit
Todd_Rogers
Update 2026.2 is in Beta 2. Should fix some Model Viewer issues.
Todd Rogers
Civil Administration at Walter P Moore
RobertEVs
The model viewer is probably just getting started. It is also missing the Realistic View and a couple other that the object viewer has available. I suspect the MV capabilities will advance further as we go along.
Wish item: Add the ability to show featureline PI's & EP's grips in the model Viewer when selected in plan view
